Guest Martyn Carter Posted January 27, 2016 Report Share Posted January 27, 2016 I own 2 flats in a converted house which is split into 4 flats. I need to change the main communal front door. I know the doors into the flats from the communal area need to be fire doors. But does the main front door into the communal hallway need to be a fire door? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted February 1, 2016 Report Share Posted February 1, 2016 If it is the front door that leads from the communal hallway to outside then it does not need to be a fire door, there could be a situation where a fire doors could be needed but that is very rare. Quote Link to comment Share on other sites More sharing options...
