Guest Emma Posted July 22, 2023 Report Posted July 22, 2023 I have the EI141. Just changed the battery, green light permanently on, red light flashes every so many secs. But pressed the test button and no alarm sounds- what does this mean? Quote
green-foam Posted July 24, 2023 Report Posted July 24, 2023 If you pressed the test button and nothing happened it means the unit is not working as it should, and as it has no user serviceable parts the whole thing should be changed A.S.A.P. either that or you did not press the button correctly. Quote
