cassiya Posted January 14, 2016 Report Posted January 14, 2016 Hi All. Can someone please help me? I am a Carpenter/ builder and just finish a job which is listed below. the home owner has asked me for a certificate so that I can get paid? I made it very clear before I started the job that I could not supply a certificate but only those issued by the manufactures? How do I go about this? Here is the list and details of what I did. 1.. took out existing glass in transom and replace with 7.2 Pyrogaurd. fitted them with hardwood beading, glued, screwed, and 30min fire seal tape both sides. All glass are etched I basically followed instruction I found online. 2.. Removed existing 100mm steel hinges and replaced with fire rated hinges with a third added to the centre, so now all doors have 3 x fire rated hinges. 3..Replaced a badly fitted door, like for like FD30 with intumescent strips, sides/top 4.. 2 x doors were cut too short by previous owner, they had wood flooring. so the gap at the bottom were 30mm. so I added a hardwood threshold to get the gap to 5mm. Thanks in advance, your help is very much appreciated. Cass Quote
Tom Sutton Posted January 15, 2016 Report Posted January 15, 2016 As far as I am aware there are no third party certification schemes for carpenters who fix, repair or modify fire doors, so who ever did the job would not be able to provide a certificate. Without inspecting your work I would not be able to say it was satisfactory but as you informed your client at the beginning you would not be able to provide a certificate have you considered taking them to the small claims court. Quote
