Guest David Posted January 1, 2016 Report Posted January 1, 2016 Hello On the EI156TLH model is is safe to disconnect the wiring socket when the green light is not on? Thanks Quote
Safelincs Posted January 9, 2016 Report Posted January 9, 2016 Hi David, make sure the power supply is properly interrupted at the fuse box before you attempt any work on the connector! If in any doubt you must call out an electrician. Harry Quote
