Guest John J Posted December 29, 2015 Report Posted December 29, 2015 Hi, I am selling a flat in a Victorian house that has been converted into 3 flats. My flat is the ground floor flat. I believe the door on to the communal hall is a fire door along with the other door from the kitchen into the bedroom (all be it older fire doors), but cannot prove they are fire doors. I bought the flat off a Housing Association and have not changed the doors. I have lived there myself and never rented and am selling to another owner occupier. My buyers solicitor is not happy about the doors as I have no proof. What is the situation, do I have to change them. JJ Quote
Tom Sutton Posted December 30, 2015 Report Posted December 30, 2015 I know of three ways to having proof that a fire door (FD) meets the required fire resistance, fit a certificated FD, it will come with the necessary documentation, fit a fire door that has been constructed in accordance with a global Assessment, it will come with the necessary documentation, finally have it checked by a qualified fire door assessor who should provide you with a report. The last suggestion you need to contact the Fire Door Inspection Service and obtain the necessary information and you should also check if the buyer's solicitor will accept a FDIS report, if not, then its a case of fitting new fire doors, best of luck. Quote
Fiona Hails Posted March 9, 2016 Report Posted March 9, 2016 Hi, There isn't any need to have them changed. Don't waste money on installing a new one. You should ask a certified fire door inspection service to take a look at your entrance and you a certificate saying they are fire resistant. It will be helpful. Quote
