Guest DavidThoma Posted November 10, 2015 Report Posted November 10, 2015 Can you please tell me the approximate distance a fully pressurized store pressure fire extinguisher can squirt a water solution? Thanks Quote
Safelincs Posted November 10, 2015 Report Posted November 10, 2015 Hi David This varies, see data tabs of water based extinguishers http://www.safelincs.co.uk/water-fire-extinguishers/ Commonly, the discharge range is 6m for water based extinguishers Harry Quote
AnthonyB Posted December 14, 2015 Report Posted December 14, 2015 If you need range you want a jet, although as most first aid attacks are started from 1-2 metres a spray is often more effective (particularly with additives) Quote
