As the clocks have just changed, why not change the battery in your smoke alarm now...........or you could wait until it starts to beep at an annoying time of the morning.
Even some mains operated smoke alarms have a back up battery that will also need changing. Safelincs do supply batteries for smoke alarms Click here
If you have an an Ei xxx smoke alarm or a Kidde mains smoke alarm and you are not sure how to change the battery, you can see the videos of how to change the battery if you Click here
