Guest Kevan Posted October 15, 2015 Report Posted October 15, 2015 Can you answer this pls we have a bg on every floor, on the ground floor is where I need clarification there is no bg at the bottom of the stairwell but there are no rooms off this landing but a fire door to a lobby there is then a final exit which does have a bg the distance is only 5 to 6 meters from the bottom of the stairs to the fianl exit are we supposed to have a bg at the bottom of the stairs thanks for any advice Quote
Tom Sutton Posted October 21, 2015 Report Posted October 21, 2015 If I understand your description, everybody in the building will have to pass a BG before they leave the premises. Providing they do not have to travel more than 30 metres to reach a BG then the provision of BG's is acceptable. Quote
AnthonyB Posted October 21, 2015 Report Posted October 21, 2015 Yep, no additional Manual Call Point needed Quote
