howieleem Posted August 13, 2015 Report Posted August 13, 2015 I have a Fike Twinflex system with a manual callpoint 402-0006 as the first thing in the chain. Then 8 sensors and then another manual callpoint at the end of line. The call point at the end of the line has the eol switched to on and the red light flashes on the front. However the red light on the call point at the start of the chain only flashes if its eol switch is set to on. I think i am correct in thinking it should have the eol switch set to off, but if i do, the red light does not flash. Any ideas? Quote
green-foam Posted August 14, 2015 Report Posted August 14, 2015 For the definitive answer may I suggest you ask Fike's technical dept. You can contact them at fstsupport@fike.com The general phone number is 01633 865 558 Quote
AnthonyB Posted August 20, 2015 Report Posted August 20, 2015 Only the device at the end of the zone wiring should have an EOL, On Twinflex call points when the EOL option is activated the LED flashes once every 5 seconds otherwise it stays off. If a call point is activated (EOL or not) it's LED will flash twice a second. Quote
Guest Mark Posted July 5, 2016 Report Posted July 5, 2016 Hi could anyone help I have a fike call point as my EOL but have no power going into it the 2 devices before have power and the EOL are to off, any ideas Quote
AnthonyB Posted July 6, 2016 Report Posted July 6, 2016 I suggest you ask this technical question on www.firealarmengineers.com/forum Quote
Guest Shandy Posted January 28 Report Posted January 28 I have a twin flex alarm system but it's been beeping and the call point under is on red constant Quote
AnthonyB Posted January 29 Report Posted January 29 This video includes resetting the call point Quote
