Guest Jaco Posted June 10, 2015 Report Posted June 10, 2015 We have a zp2 panel, and on the loop is 3 manual call points, 1 of which activates in a fire condition at odd times, without being physically activated. What could be the cause of this? Your assistance is appreciated. Quote
green-foam Posted June 10, 2015 Report Posted June 10, 2015 I would say without seeing it, all any one can do is guess, you really should have it looked at by a fire alarm engineer. Why not call the company who maintain your fire alarm? Quote
Guest Jaco Posted June 11, 2015 Report Posted June 11, 2015 They have been and also replaced the unit, I don't think they know what could be wrong. That's why I'm trying to find out what the possible causes might be. Quote
green-foam Posted June 12, 2015 Report Posted June 12, 2015 I can understand that you are trying to resolve the problem, but as I first said ............ without seeing it, all any one can do is guess............ It could be any of 507 possabilites all of which can not be "diagnosed" via a forum Quote
Tom Sutton Posted June 13, 2015 Report Posted June 13, 2015 Green foam is right it cannot be "diagnosed" via a forum but you have had the MCP changed so it is unlikely to be that, I assume the the system is working in all other aspects then you are left with the wiring where there could be an intermittent fault on the detector circuit, like breakdown of the insulation, pesky rodents. :rolleyes: Quote
