Guest JaniceHutto
Is there a standard height that a sticker should be at on a fire door?
The fixing height for mandatory signs is recommended at 1500 mm ("eye level"). Each door must carry a sign on both faces unless it is an access to ducts etc. where there is no approach from the other side. (ADB - Appendix B:8)
  • 1 year later...
