Hello,
I followed all the instructions to remove the fire alarm. However, even though I turned off the power source, the red light keeps flashing every minute, and the alarm keeps beeping a few times.
Is everything all right as long as the green light is off, or should I do something else?
Thank you!
Hi Meursault
As soon as you turn the power off, the green light, which indicates 'mains power on' will be replaced by a red light, which indicates 'power cut-off' and the unit will beep (powered by the internal backup battery).
So you should now be able to remove the unit
Harry
