Guest PeterSm Posted May 20, 2015 Report Posted May 20, 2015 I'm concerned that a door recently fitted is not an FD30 door. A flat in the block was recently burgled and the door was split, so I have some photos of the door's construction. Who can I contact for advice ? Quote
Tom Sutton Posted May 21, 2015 Report Posted May 21, 2015 You could contact Fire Door Inspection Scheme they may be able to help but it may cost. Quote
Guest Neil Ashdown Posted May 21, 2015 Report Posted May 21, 2015 Hi Peter, Try www.fdis.co.uk/inspector You will find contact numbers so you can get a quote first. Regards, Neil. Quote
