What type of wood is used for fire doors
Guest Christopher
The documentation that should have accompanied the fire door will instruct you how the fire door should be installed, including which door furniture you should use. If it was not bought as a fire door set they it should explain how to construct the frame and which timber should be used, there are many that could be used.
