Guest Vivskelh Posted January 20, 2015 Report Posted January 20, 2015 I work for the Welsh Air Ambulance charity shop as a volunteer. Can you please advise whether it is legal to up-cycle materials and fillings which have been donated to the shop into craft items to sell in the shop? As an example, we can turn a bed sheet or duvet cover into a doorstop or draught excluder to sell in the shop. In doing this we need to use a filling. Is it legal to use a bag of filling which has been donated (no markings on the bag so we don't know where it's from) or, alternatively, buy a new bag from a reputable supplier? Quote
Tom Sutton Posted January 23, 2015 Report Posted January 23, 2015 It depends on what you are making, if it falls within the Furniture and Furnishings (Fire Safety) Regulations then it would have to meet the requirements of the regulations. Check out Guide to the Regulations and decide if you need to comply with the regulations but most furnishings in the home fall under the regulation. This means, Filling materials must meet specified ignition requirements. Upholstery composites must be cigarette resistant. Covers must be match resistant (with certain exceptions as outlined in Section 8.2 and Appendix A5). A permanent label must be fitted to every item of new furniture (with the exception of mattresses and bed-bases). A display label must be fitted to every item of new furniture at the point of sale (with the exception of mattresses, bed-bases, pillows, scatter cushions, seat pads, loose covers sold separately from the furniture and stretch covers). The first supplier of domestic upholstered furniture in the UK must maintain records for five years to prove compliance. Quote
Guest AndreaGib Posted June 18, 2015 Report Posted June 18, 2015 We have Lots of materials in our shop that are unfit for sale, or we have in abundance, that we hope to upcycle to try and make a little more money. How are we covered if we turn a jumper into a cushion cover for example, or silk scarves into a curtain. How do we label them to be compliant with fire regulations. Am keen to crack on and make some lovely stuff, but want to ensure that safety comes first. Thank you in advance. Andrea Quote
Tom Sutton Posted June 18, 2015 Report Posted June 18, 2015 Depends on what you intend to make, for instance curtains in the domestic situation is not subject to the Furniture and Furnishings (Fire) (Safety) Regulations 1988 (amended 1989, 1993 and 2010) but scatter cushions are. If you study the guide it will detail all the items that are subject to the regulations and to what extent, also the labeling/testing that is required. Check out http://www.fira.co.uk/document/fira-flammability-guide-october-2011pdf.pdf Quote
Guest Jane Posted October 24, 2018 Report Posted October 24, 2018 Hi, couldn't see the regulations on your page... I would like to upcycle sample printed silk pieces into scatter cushions... does this silk cushion cover fabric have to be fire retardented? and if so, does it need a label? Quote
Tom Sutton Posted October 25, 2018 Report Posted October 25, 2018 The Regulations apply only to the filling material of pillows, scatter cushions and pads of the type supplied for use on the seats of wooden chairs. Foam fillings must pass the specified test. When non-foam fillings are used either the filling material itself must pass the appropriate test or, if the item has primary cover, then the filling material together with that primary cover must pass the specified test. The Regulations do not apply to the decorative cover of scatter cushions and seat pads, or to covers for these items which are sold separately. If the regulations apply then it will have to have the required labels. Check out Fire safety of furniture and furnishings in the home - A Guide to the UK Regulations guide 1 or Fire safety of furniture and furnishings in the home - A Guide to the UK Regulations guide 2 Quote
Guest furnishings from Abroad Posted November 10, 2018 Report Posted November 10, 2018 Hi, I am an upholsterer. In the last month I have had 3 instances of newly purchased furniture that is constructed using the really bad polyeurathane foam. The first was a wooden dining chair, bentwood design, with a crossed back. This design is very common in the uk, it had a rush seat but underneath was the foam. The other two instances were people who had been living in Singapore and Hong Kong and had brought back high end designer chairs/sofas. All these were purchased recently and contained so much really bad foam. I had an opportunity to burn two of the seat cushions outside and the result was awful, it was like burning a can of petrol and the awful brown tar residue was stuck to the ground like treacle. Quote
Tom Sutton Posted November 12, 2018 Report Posted November 12, 2018 The Regulations apply only to manufacturers, importers and retailers, you and not buyers so if they wish to put there families at risk that is their right but they should be warned. Another problem is many believe the regulations are not fit for purpose and should be revised which has started but unfortunately the government is dragging their heels. Check out Fire safety of furniture and furnishings in the home - A Guide to the UK Regulations guide 1 or Fire safety of furniture and furnishings in the home - A Guide to the UK Regulations guide 2 Quote
Guest Zsu the upholsterer Posted November 13, 2018 Report Posted November 13, 2018 Hi Tom, thank you for your reply and the regulations. Very useful. I personally test the foam with a match. I will not reupholster anything that I consider dangerous and replace foam whenever suspicious. Do not allow customers to provide their own fabric and when it's explained to them they always see the sense. You are right the regulations do not go far enough, obviously reupholstering something that is not safe means the life of it's potential to harm has been extended. Great blog! I am supposed to have retired but love my job too much. Quote
Tom Sutton Posted November 14, 2018 Report Posted November 14, 2018 There should e more like you,cheers! Quote
Guest Mary Posted October 21, 2020 Report Posted October 21, 2020 Hello, I am a small scale producer/maker of scatter cushions. The outer design cover is made from 100% wool; mostly British wool. I have been buying the cushion inserts from Dunelm, which have the necessary fire testing regulation label attached. I would like to make my own cushion inserts using fire retardant cotton curtain lining (probably purchased from Dunelm!) and filled with 100% raw fleece. Alternatively I could simply fill the cushion cover itself with raw fleece and do away with the insert. I am unsure what testing and/or labelling will be required and would greatly appreciate your advice please. Thank you very much. Quote
Tom Sutton Posted October 24, 2020 Report Posted October 24, 2020 Check out page 27 and 29 of Fire safety of furniture and furnishings in the home A Guide to the UK Regulations which may be difficult to understand so I would suggest you contact FIRA. Quote
Guest Tracey Posted November 15, 2020 Report Posted November 15, 2020 Hi i have started upcycling such things as stools/chairs to then sell on. 1. Do I need to meet fire safety regulations? 2. How do I meet these regulations? Thank you for any advice. Quote
Tom Sutton Posted November 19, 2020 Report Posted November 19, 2020 If there are upholstered then the regulation apply therefore check out Fire safety of furniture and furnishings in the home A Guide to the UK Regulations and https://www.firesafe.org.uk/furniture-and-furnishings-fire-safety-regulations-19881989-and-1993/. Quote
Guest DebbieM Posted May 19, 2021 Report Posted May 19, 2021 Hello Tom, I’ve been picking though previous posts but can’t quite find a definitive on what I’m looking for so I’m hoping that you can help. I’m hoping to turn a hobby into a small business and one of the products that I’m looking to make will be draught excluders (the cushion type). The covers are permanently fixed. I buy upholstery fabrics via third parties who buy containers from upholstery factories so can I assume the fabrics have already met the necessary tests regarding upholstery? Is this sufficient enough or would I have to have certification for every fabric (these are roll ends and so there would be many different fabrics changing often and sometimes I ‘patchwork’ several in one item). I buy 100% polyester Hollowfibre filling (marketed as toy / cushion filling). What regulations would I need to look to please with regards to testing and labelling I order to be compliant? I’m not sure if these would fall under cushions as technically they are not for the same purpose though they have the same components. Thank you in advance if you are able to signpost for me. Quote
Guest jay06 Posted May 24, 2021 Report Posted May 24, 2021 Good evening, I have researched the fire safe regulations well but am struggling to find an answer to my specific question and am wondering if you can help. I am looking at selling upholsetered furniture that I am making and upholsterin myself. I am using recycled curtains as my outer fabric to save textile waste and recycle fabric that is unwanted. Do I need to get my fabric tested as I am aware curtains do not need to meet the same criteria as upholstered items?? And if I do need to do testing, would I have to test every different curtain I use for each product. I have been trying to get answers for two weeks and am really keen to start my shop and sell my items but want to ensure I do so following all the guidelines required of me. Any help would be really appreciated ? Thanks! Quote
Tom Sutton Posted May 29, 2021 Report Posted May 29, 2021 Trading Standards Department are the enforcing authority they would be best to respond to this question. What I can say is any materials used to satisfy the regulations needs written proof that they meet the required fire resisting standards. Quote
