Guest DavidScho Posted December 10, 2014 Report Posted December 10, 2014 I live in a 3 storey town house where there is only access to the garden at the rear. This is to say that the neighbours at either side have built hedges, fences and sheds, only allowing me to exit the property from the front. Also at the rear there is a wall and then a 10 foot drop in to a beck. this is probably about 10 metres from the rear door. Does this contravene any fire safety regulations Quote
Couvre-Feu Posted December 11, 2014 Report Posted December 11, 2014 See section 2 of AD B for Dwelling Houses and diagram 4 - for an exit route to be accepted into an enclosed courtyard or garden the depth of back garden should exceed the height of the house above ground level or where a rear extension is provided the height of the extensions (whichever is greater). Bear in mind this is only if your access route to the front door is unacceptable - i.e. you have to pass through a risk room in order to exit the property - if you pass through a normal hallway the premises should be fine. Do you mind if I ask why you're raising this as its come up a few times recently? Quote
Tom Sutton Posted December 12, 2014 Report Posted December 12, 2014 It depends on the layout of your property and the travel distances to your front door, many houses have this situation you should check out approved document B (fire safety) not all houses need an alternative means of escape. Quote
Guest Guest Posted May 24, 2020 Report Posted May 24, 2020 Friend of mines garden (end terrace) is escape access for his property and 2 others. One neighbour and friends just walk through his garden even if not an emergency. Is this allowed?? Quote
green-foam Posted May 26, 2020 Report Posted May 26, 2020 That is a legal matter, not a fire related matter. I suggest your friend seeks legal advice. (But no, If it were me I would not be happy about it) Quote
Guest Lou Lou Posted August 4, 2021 Report Posted August 4, 2021 Hi I am renting a small cottage with front door leading into living room, very narrow hallway and into kitchen. The back door leads to a garden. Either side neighbours have fencing up. One side has a house built inches from the fence. The other side has a garage with a small space between that and their house. How would I exit if a fire was in front of house ?? I’m sure this doesn’t comply with fire regs. Quote
AnthonyB Posted August 4, 2021 Report Posted August 4, 2021 It's fine, lots of houses only have one exit door. Shut your doors at night, make sure your smoke alarm works. Quote
Guest Tiny Posted August 10, 2023 Report Posted August 10, 2023 Hi. I rent a cottage from the trustees of a small village hall. The village hall has an enclosed garden. The trustees want to put a fire exit in the fence between my garden and the hall garden which will remain unlocked and so give access into my garden. Can I refuse this on grounds of lack of privacy and risk to my security? Quote
AnthonyB Posted August 11, 2023 Report Posted August 11, 2023 Not a question or a fire safety forum sadly - more a landlord/tenant/property law issue, Citizens Advice are a useful free initial source of advice. Quote
Guest CMW Posted October 27, 2023 Report Posted October 27, 2023 @Guest Tiny - fire exit gate in the fence doesn't have to be unlocked - it can be fitted with a crash bar or push handle type fire exit lock. This will allow it to be opened from the inside in an emergency, and from the outside with a key. Quote
Guest Rus08 Posted April 7, 2024 Report Posted April 7, 2024 our garden has an exit open, for emergency but except for two neighbors, they also closed it. Example if my way the right will be blocked, I would like to go to the left, but it is closed by the neighbors. What rules Quote
Guest Julie Posted September 14, 2024 Report Posted September 14, 2024 Shop next door to my home, put a fire exit door in the back of their shop . That opens up onto a overgrown copse that there is no way of escape.. The land is not owned by the shop that is rented nor the landlord.. it's not even a proper fire door, it has a handle and lock on the outside. And yet you can not access the outside , only from inside the shop. It's a worrying and illegal.. Quote
AnthonyB Posted September 17, 2024 Report Posted September 17, 2024 If they don't have a way leave to access the land then it can be obstructed - it's a civil matter and you should take legal advice from a property law specialist. Quote
