Lone worker protected by fire door
Guest AlisonMcC
We need to fit a fire door to where a lone worker is situated at the top of some stairs. In this situation should we be fitting a 30 minute or 60 minute fire door? I am unable to find a regulation that helps with this query.
There is no way of working this out you would need a lot more information, I would suggest you consult the Fire Risk Assessment and the answer should be there.
