Guest Sydney Posted November 17, 2014 Report Posted November 17, 2014 Hi all, I am a high school engineering student and am working on the downfalls of smoke alarms in hopes of developing a final project by the end of the year. Would you all mind taking my survey? Here is the link: https://www.surveymonkey.com/s/XGHSJRKthank you all so much! :) Quote
green-foam Posted November 18, 2014 Report Posted November 18, 2014 On line surveys such as yours do not give good results, since you can "adjust" the way you look at the figures to give the results you want. I wish you luck with your project, but ask yourself this. At the end of the day, can you really make a better smoke detector that is affordable? If its not affordable it will be a "gimmick" Quote
