Guest anonymous Posted October 21, 2014 Report Posted October 21, 2014 Hello, Please could you give me advice on the following. I work for a college that is based in a prison. The building is used to teach offenders in classes and a place of work for teaching staff.There are over 10 members of staff up to 90 offenders the building is 2 storeys with approx 20 rooms plus store cupboards. Rooms are used as staff room, cookery room with kitchen, computer rooms and offices. The fire alarm for the hole building is down and not working, but managers are still insisting staff carry on using the building as normal, With a fire Marshall patrolling the building, while learners are present. Teaching staff are in the building all day. Is this legal or a serious breach of fire safety. And can I refuse to work in the building. Kind regards Quote
Tom Sutton Posted October 22, 2014 Report Posted October 22, 2014 The fire alarm is to warn persons in the building that there is a fire in the building and can be initiated by somebody operating a manual call point or a fire detector, detecting a fire and operating a sounder. So if you can devise a procedure that will achieve the same objects then it could be acceptable for a short period of time while fire alarm system is repaired. People can be the best fire detectors; they usually smell the smoke long before seeing the fire. As soon as they are aware of a fire they need to be able to warn the rest of the building and this is where a procedure has to be formulated to ensure all relevant persons are made aware and can evacuate the building safely. For instance you could provide a contact point using the internal telephone system who in turn could contact the fire marshals to evacuate the floors ensuring all people evacuate safely, when only staff is present then the procedure would have to be modified. Without knowing a lot more about the building I could not formulate a procedure but I am sure there is staff that could. There is no legal or a serious breach of fire safety it is all about risk assessment and formulating a satisfactory procedure. If you are very concerned you should contact the enforcing authority, who are the local Fire and Rescue Service. Quote
Tom Sutton Posted October 23, 2014 Report Posted October 23, 2014 I stand corrected the fire and rescue service is not the enforcing authority, as it is crown property and Office of the Chief Fire and Rescue Adviser, Crown Premises Fire Safety Group are the enforcing authority. http://webarchive.nationalarchives.gov.uk/20100413151441/http://communities.gov.uk/documents/fire/pdf/1496020.pdf Quote
Guest AndrewLlew Posted February 3, 2015 Report Posted February 3, 2015 There are rumours at my workplace that the fire alarm system is off for some reason and has been for days, reason unknown. Is this legal and who would I have to contact with my concerns ie. Fire warden for purposes of an inspection Quote
green-foam Posted February 3, 2015 Report Posted February 3, 2015 Would it not be a good idea to actually look at the fire alarm panel first? Quote
Guest Ray Posted August 16, 2018 Report Posted August 16, 2018 Hi, Looking for some advice here. Can my employer turn off their firm alarm system because work is going on on their premises. It is a large Warehouse & it is noisy. Is this against the law? Quote
Tom Sutton Posted August 17, 2018 Report Posted August 17, 2018 Your employer is not necessarily committing an offence under The Regulatory Reform (Fire Safety) Order 2005 if he/she has alternative arrangements in place, if evacuation in case of fire is necessary, which all staff should be instructed on. It all depends on the premises involved and the fire procedure adopted. If you are still concerned contact the local fire and rescue service as they are the enforcement authority. Quote
Guest Guest Phil Posted November 29, 2019 Report Posted November 29, 2019 Can a building be slept in without a functioning alarm system? we have an old staff sleeping accommodation building on site and the alarm system has failed due to age. My thoughts are that the building should be evacuated until serviceable would you agree? Quote
AnthonyB Posted December 3, 2019 Report Posted December 3, 2019 No it can't, you are putting relevant persons at severe risk and it's one of the few cases where a Fire Service inspector would likely jump straight to a Prohibition Notice and if not complied with prosecution. Sleeping risk cases that get to court often have custodial sentences, both suspended and actual imprisonment. Depending on the size, nature and layout of the premises a temporary solution might be possible. Quote
Guest Chris Posted February 2, 2020 Report Posted February 2, 2020 hi i have just noticed that my fire alarm sounders do not sound on a fire alarm test. There is no sounder fault showing on the panel. Does anyone know the reason why they have stopped working? Quote
AnthonyB Posted February 2, 2020 Report Posted February 2, 2020 Several possibilities, you should really get your service engineer out. Quote
Guest Guest Paul Posted May 5, 2021 Report Posted May 5, 2021 I note the comments in relation to sleeping accommodation. If a fire panel was to fail in the middle of the night would you need to evacuate the building or would you call an engineer and wait for them to fix it and hope for the best? This is based on the system is well maintained and regularly tested, like a lot of technology everything has the potential to just unexpectedly stop working. The consequences of having people outside in the middle of winter can cause welfare issues. Is there anything in the legislation that would allow the premises to continue until the morning? Quote
Guest Wip Posted May 10, 2021 Report Posted May 10, 2021 Can u stay in a building if the fire alarm is broken and won't be fixed for a rew weeks Quote
AnthonyB Posted May 10, 2021 Report Posted May 10, 2021 Not unless some temporary measures are in place to ensure the alarm can still be promptly raised - the size and type of premises determines what these would be. Quote
Guest Jock Posted January 16, 2023 Report Posted January 16, 2023 Can hotel guests stay in a room where the fire alarm sounders in there room are silenced ? Quote
AnthonyB Posted January 18, 2023 Report Posted January 18, 2023 Not really unless the premises have temporary mitigation measures in place. The room sounders are there because the corridor sounders will not rouse a fair percentage of people in bedrooms - studies showed people asleep in unfamiliar locations actually need higher sound pressures hence the change in standards over 40 years ago to have sounders in bedrooms. Quote
