Guest Tara Posted October 13, 2014 Report Posted October 13, 2014 Hi, I recently had a smoke alarm fitted by an electrician. It may not be relevant, but as he fitted it, I noticed that he chopped a few wires. It is only one or two months and was 'apparently a new smoke alarm, but the green led light that was always on, has switched off, the red led still flashes occasionally. I wondered if this was serious, or something which I need to fix. . ? many thanks for your time. Quote
Safelincs Posted October 13, 2014 Report Posted October 13, 2014 Hi Tara It really depends from the model but most mains powered alarms indicate correct power supply with a green light. If this has changed you should call back your electrician. Harry Quote
Guest Tara Posted October 13, 2014 Report Posted October 13, 2014 I appreciate your advice. I that I may just have to do that. . : ) tara. Quote
