Guest AdrianBish Posted August 28, 2014 Report Posted August 28, 2014 Hi, can you help, please? Is maintained lighting required for a fire escape at the rear of a special needs home Quote
Tom Sutton Posted August 28, 2014 Report Posted August 28, 2014 The Regulatory Reform (Fire Safety) Order 2005, states emergency routes and exits requiring illumination must be provided with emergency lighting of adequate intensity in the case of failure of their normal lighting. You refer to maintained lighting do you fully understand the meaning because there is maintained and non maintained emergency light and either would be acceptable. To help further I would need to know what you mean by special needs home. Quote
