Guest Sandra Tingley Posted February 7, 2014 Report Share Posted February 7, 2014 Hello we are currently planning the layout of our office and wonder how much space we need to leave around the fire exits Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted February 7, 2014 Report Share Posted February 7, 2014 There is no set area just sufficient space so you do not restrict people passing through the fire exit. Quote Link to comment Share on other sites More sharing options...
Guest AndrewColl Posted March 3, 2015 Report Share Posted March 3, 2015 Hello there. I was wondering if there is a regulatory clearance distance from a fire exit door. Thank you for your help Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted March 4, 2015 Report Share Posted March 4, 2015 There is no regulatory clearance distance from a fire exit door other than there should be sufficient clear space so the means of escape can be used effectively. Quote Link to comment Share on other sites More sharing options...
Guest john Posted June 9, 2016 Report Share Posted June 9, 2016 Hi,there is a car parked outside my fireexit door 4ft away is that legal??thank s Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted June 10, 2016 Report Share Posted June 10, 2016 When the door or doors are fully open is there a route away from the building to a place of safety which doesn't means squeezing between cars also who does the car park belong to? Quote Link to comment Share on other sites More sharing options...
Guest jes Posted June 20, 2016 Report Share Posted June 20, 2016 Hi We have just had a new machine installed in the factory which runs in front if the fire escape is this allowed It would mean to escape people would need to go around the back of the machine to escape Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted June 21, 2016 Report Share Posted June 21, 2016 Your question does not give sufficient information to be able to give a definitive reply. It depends if the machine excessively restricts the access to the fire exit and is there an acceptable escape route available to the fire door? The width of the fire door would dictate the width of the escape route required. Quote Link to comment Share on other sites More sharing options...
Guest Carol Posted September 10, 2019 Report Share Posted September 10, 2019 I have to add an additional desk in the office and it is quite close to the emergency exit. What clearance do I need from the door Quote Link to comment Share on other sites More sharing options...
Guest Karen Posted September 11, 2019 Report Share Posted September 11, 2019 Hi, I was wondering if you could indicate any guidance or Regulations on whether there ought to be considerations of fire exits, which open outwards, onto busy public footpaths? I have a general concern in relation to the door opening suddenly and potentially injuring a pedestrian? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted September 11, 2019 Report Share Posted September 11, 2019 There is no specified clearance as long as the door can be opened to its full width and it doesn't cause a restriction of the width of the mean of escape. Quote Link to comment Share on other sites More sharing options...
Guest Hello ronnie Posted October 2, 2019 Report Share Posted October 2, 2019 Hi. My bedroom window is facing a parking lot which park's trucks in front of the fire escape ladder.God forbid there's a fire ,the ladder wouldn't be able to drop. What should I do? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted October 3, 2019 Report Share Posted October 3, 2019 Do you or your landlord own this land, if not you should have an legal agreement with the owners which should detail the do and don'ts. If you do own the land you should make arrangements the prevent parking in that particular area or conduct a FRA to see if an alternative means of escape can be arranged. Quote Link to comment Share on other sites More sharing options...
sharon Allsop Posted December 17, 2019 Report Share Posted December 17, 2019 A fire escape route opens out onto a yard that may incur traffic. It has been noted a barrier guard is required. Is there a legislation to states distance from the door, type of guard etc? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted December 19, 2019 Report Share Posted December 19, 2019 I am not aware of any, but the barrier would have to be a reasonable height and sturdy, also not reduce the width of the means of escape so the distance from the door would have to be equivalent at least to the width of the door, a little wider would be better. You see lots of barriers on the high street usually at pedestrian crossing you could use them as a guide. Quote Link to comment Share on other sites More sharing options...
Guest Billy Lindsay Posted January 28, 2020 Report Share Posted January 28, 2020 Hi Tom I have currently planned walk ways round my factory my question is do you need to have the walk ways leading to all fire exits? I have 16 people on the factory floor and 5 fire exits? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted January 29, 2020 Report Share Posted January 29, 2020 You do not provide sufficient information you would need to know the means of escape scheme, travel distances and much more. What does your fire risk assessment or fire strategy document say. I would suggest you employ the services of a fire risk assessor who could advise you what you require. Quote Link to comment Share on other sites More sharing options...
Guest Flexable0013 Posted August 11, 2020 Report Share Posted August 11, 2020 Hello, my work brings me to the airport alot. The small local airport has placed freestanding signs in front of all the main doors/exit doors of the building. Ive notice people walking in bumping into the sign or even knocking them over to walk around them. The sign is about 3 foot tall by 2 foot wide. Would this be considered a obstruction/clutter of a emergency exit? Is their a distance on how far away a business can place this kind of sign/objects in front of a exit door? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted August 21, 2020 Report Share Posted August 21, 2020 There is no specific guidance on the distance objects should be, so they do not cause an obstruction, it would be up to the enforcing officer to decide if it was causing an obstruction. Quote Link to comment Share on other sites More sharing options...
Guest guest tom Posted August 22, 2020 Report Share Posted August 22, 2020 is it legal to park directly in front of a fire exit Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted August 26, 2020 Report Share Posted August 26, 2020 Assuming it is on the public thoroughfare, I am not aware of any legislation thats makes it illegal but any publicly minded person would realise the problems he/she would be causing if the exit was used in a fire situation. Quote Link to comment Share on other sites More sharing options...
Guest Guest Luke Posted May 18, 2021 Report Share Posted May 18, 2021 Hello, I wonder if you can help I run a shop , and looking to use a outside area hat we haven't used before by putting a new door in to lead from the show room out to this area - but this outside area is closed in, like a courtyard the only way in and out to it would be through the show room - would this be allowed? so in case of fire / emergency the customers would need to go through part of the shop to the fire escape, the fire exit from the new door would be 7m approx away sorry If I have not described this well, but would really appreciate your advise Many thanks Luke Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted May 21, 2021 Report Share Posted May 21, 2021 It all depends on the layout if you could get a 30 minute fire resistant separation between the route into the yard and out of the yard it could be acceptable otherwise you would need a separate way out the yard. Quote Link to comment Share on other sites More sharing options...
Guest Christian Johnson Posted August 18, 2021 Report Share Posted August 18, 2021 Hello Tom, I am planning on having a loft bed in front of my window with the desk. I was wondering how much space needs to be let for firefighters if we were to have a fire. It would end up being like 30 inches is that plenty of room? Thanks Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted August 20, 2021 Report Share Posted August 20, 2021 There is no need to concern yourself about firemen if they have to enter via a window a piece of furniture not going to stop them anyway it is unlikely they would use a windows to enter. More of a problem if the window is an escape window as you would have to provide access to it. Quote Link to comment Share on other sites More sharing options...
