Guest Dee Posted November 16, 2013 Report Posted November 16, 2013 Hi,I walk in a large technical site which has 3 designated fire doors which are also used as a daily entrance/exit doors. As the place I work is a technical site,security is of the upmost importance and entry is strictly limited and entrance is by way of a card. One of the doors has developed a fault which means it does not automatically lock,this is being investigated,but meanwhile it has been manually locked. My query is whether this falls foul of the law,I will state there are 2 other exits closer to the offices. Quote
Safelincs Posted November 17, 2013 Report Posted November 17, 2013 Hi Dee I assume you mean these doors are three fire exits doors rather than fire doors (fire exit doors do usually not have to be fireproof doors)? I would assume that the number of fire exits was determined when the building was designed, so must have been deemed necessary in the first place. I would therefore assume that the company has to take compensation steps to overcome the impact of the failing exit door, eg by not using part of the building and/or prepare alternative exits. Another solution would be to add a push bar to the faulty exit door. The door can then still act as exit, even though nobody could enter (as long as there are no other locking mechanisms). Harry Quote
Guest Mick Posted November 18, 2013 Report Posted November 18, 2013 Can you also advise if it is ok to fit a door closer on a fire exit door. Your assistance would be appreciated. Mick Quote
Tom Sutton Posted November 18, 2013 Report Posted November 18, 2013 I assume we are talking about final fire exit doors and as you have most probably passed through a number of fire resisting doors with self closer why not the final fire exit door but usually they are not required. Quote
Safelincs Posted November 19, 2013 Report Posted November 19, 2013 I guess for security reasons a door closer would be important. It is not a problem for fire exits to have door closers, as long as they are not set too stiff and do not restrict the opening of the door. Quote
