Steve F Posted February 7, 2020 Report Posted February 7, 2020 I own a flat on the 2nd floor which is the top floor at the end of the corridor , each floor has 4 flats, so 12 in total, it was built in the 1970 concrete construction. My problem is last owner fitted a standard front door, not a fire door arguing that being the last flat nobody would be passing the front door in the event of a fire, which turns out to be incorrect , BIG TIME So I have some questions 1, can i get a internal FD30 fire door fitted to the front door of the flat or does it need to a external FD30, whats the difference? 2. i have a professional chippy that has fitted many fire doors before, if he adheres to the door manufactures fitting instructions can i legally get him to fit it.I judge him as competent to do the job, He has good knowledge of smoke strips etc. 3 the original fire doors in the other flats fitted in the 1970's don't have self closers fitted ,should they have ? now Thanks in advance for your help. Quote
Tom Sutton Posted February 10, 2020 Report Posted February 10, 2020 1. The major differences between external and internal doors are the style/width also external doors are usually fitted with weather boards. Most external exit doors do not need to be fire resistance and its location will decide if it requires to be fire resistance. In your case you require a FD30s fire door, complete with an approved self closer, the width will depend on the degree of security you require. 2. The Regulatory Reform (Fire Safety) Order 2005 requires all work should be carried out by a competent person who is a person who has sufficient training and experience or knowledge and other qualities to enable him properly to assist in undertaking the preventive and protective measures. If you can prove, in the future, should you require to then you should be covered. 3. All doors opening into a protected route are required to be FD30s fire doors, fitted with approved self closing devices. Quote
Steve F Posted February 10, 2020 Report Posted February 10, 2020 Thank you for info most helpful Quote
Guest Marcin Posted July 21, 2020 Report Posted July 21, 2020 Hello I am an experienced carpenter and would like to know where can I go to get trained or get a qualifiction that will allow me to install fire doors Quote
Neil ashdown Posted July 22, 2020 Report Posted July 22, 2020 https://www.firedoorscomplete.com/fire-door-training Quote
Guest ElsieHG Posted July 25, 2020 Report Posted July 25, 2020 Hi Before Grenfell our double glazing installers successfully fitted compliant fire safety doors for a number of years and are all fully aware of the regulations governing installation. My question is now that fire doors have been retested and are now back on the market do our installers now need to be accredited or certified to install them or can we continue without as we have been advised both? Quote
Neil ashdown Posted July 27, 2020 Report Posted July 27, 2020 There is currently no legal requirement for a fire door installer to possess a dedicated qualification or certification. However, building operators must comply with the requirements of the Regulatory Reform (Fire Safety) Order 2005. Articles 17 and 18 deal with maintenance and competence. Quote
ElsieHG Posted July 27, 2020 Report Posted July 27, 2020 33 minutes ago, Neil ashdown said: There is currently no legal requirement for a fire door installer to possess a dedicated qualification or certification. However, building operators must comply with the requirements of the Regulatory Reform (Fire Safety) Order 2005. Articles 17 and 18 deal with maintenance and competence. Thank you Neil Quote
Guest Magic Posted October 6, 2020 Report Posted October 6, 2020 Hi everyone, the only thing you need to install or work on a fire door, is to be Competent. this means either training, experience, qualification, knowledge. But understanding your limits, there is no need for third party accreditation. Magic Quote
Guest Tony Posted December 14, 2020 Report Posted December 14, 2020 Hi Graham, can a competent carpenter cut a hole in a fire rated door, for a fire rated letter box and it be ok under the regulations? Thanks, Tony Quote
Neil ashdown Posted December 17, 2020 Report Posted December 17, 2020 Depends what is permitted under the requirements of the door leaf manufacturers certification data sheet. Is this a new fire door leaf? Or have you fabricated the door from a fire door blank? Or are we talking about an existing fire door but with no evidence of fire performance? Quote
Guest Paul Rodgers Posted April 18, 2021 Report Posted April 18, 2021 Hi, hope that you can help. We live in small bock of private apartments and each of the thirty six leaseholders own the free hold. We run an in-house management company and have a board and appointed chairman. He has employed a general building maintenance company who have undertaken various repairs. We have had a fire safety inspection carried out and it was recommended that fire doors be fitted to replace the ones on the lower ground floor that give access to the waste bins. In fitting these the contractor has failed to seal the casing to the ceiling leaving a gap of some eight millimetres. The chairman has informed the residents not to question the contractor who, I believe, is incompetent. The work was carried some twelve months ago and no inspection of the work has been carried out since. Which authority do I report this too. Any help would be gratefully received. Quote
AnthonyB Posted April 19, 2021 Report Posted April 19, 2021 As it is in the common parts, it would be the fire service who enforce any perceived sub standard fire safety works that leave a risk to relevant persons. Quote
Guest Alan peters Posted October 24, 2021 Report Posted October 24, 2021 On 14/11/2013 at 11:37, Guest Neil Ashdown said: Hi, There are ways you can train your installers and schemes you can join to enable you to provide evidence of your competence. The Fire Safety Order defines a Competent Person as 'someone with sufficient training and experience, qualifications and knowledge to be able to implement fire safety measures (some or all) in a building'. www.fdis.co.uk - The Fire Door Inspection Scheme provides on-line education for all who work with fire doors. There are two levels, the Diploma in Fire Doors and Certificated Fire Door Inspector. www.firas-database.co.uk - FIRAS is a third party accredited installer scheme and they offer training to installers and periodic audits of member companies installation work. If you don't require training but require a Competent Person to sign off your installation work you could appoint a CertFDI fire door inspector at www.fdis.co.uk/inspector Regards, Neil. Hi Neil , l hang fire doors, l would like to be able to certify the doors l hang ? Regards, Alan Quote
Neil ashdown Posted October 26, 2021 Report Posted October 26, 2021 If you would like some fire door installation training you could 'google' "Fire door training". There are a few providers that have websites. Or if you don't require training, you could look at UKAS accredited third party certification schemes for fire door installation. Quote
Guest Keith Warwick40 Posted March 13, 2022 Report Posted March 13, 2022 Hello, My local authority required me to install a FD30S at home in the block of flats where I live. I am in property and asked my Joiner /Carpenter of some years experience working on B1 Residential and other buildings, to install the door for me, under the Competent Persons Scheme as at the time 18 months ago, getting FD30s doors and someone to install them was not so easy to find. , He and his mate installed the door following manufacturers guidelines using appropriate fire retardent materials etc..he has done a few so knows the score. The council are asking for an installation certificate which of course he does not have. What to do? Is he required under the scheme to issue one he does not have or? As i understood the scheme if the person doing the installation has appropriate skills and can do the job and can demonstrate that then he is not required to register with any body to be considered as a competent person. Is that correct. I have offered to get a Third Party FD Installer certificate to confirm it meets with requirements to the council but they say the people who sold me the door and installed it must issue an installation certificate. Which i think is wrong as that would be self certification and as far as i know it has to be ratified by a third party Grateful for any help on this especially as the authority in question is RBKC responsible for Grenfell incredible as that may seem coming from them Keith Quote
Neil ashdown Posted March 19, 2022 Report Posted March 19, 2022 There is no legal requirement for the installer to provide a 'certificate of installation'. If this is RBKC policy then you would expect that they would notify you accordingly ahead of the installation work. Quote
Guest Fire door installation Posted October 7, 2022 Report Posted October 7, 2022 Hi where can I find a competent tradesperson to fit an FD30s door with locks hinges and frame to the entrance of a flat Quote
Rahel Lock Posted October 10, 2022 Report Posted October 10, 2022 Hi Safelincs offer a certified installation service carried out by qualified engineers. More information can be found here: https://www.safelincs.co.uk/fire-door-installation/ Quote
Guest Matt J Posted February 1, 2023 Report Posted February 1, 2023 Hi all, we are joinery company who basically do house bashing and apartments from time to time, what certificate to we need to install fire doors in town houses and apartments. Thanks. Quote
Neil Ashdown MAFDI Posted February 1, 2023 Report Posted February 1, 2023 Whilst there is no mandatory requirement for certification, fire door installers should be competent persons. https://www.legislation.gov.uk/uksi/2005/1541/article/18/made If you are interested in fire door installation training https://www.firedoorscomplete.com/training-qualification Quote
