Guest GrantT Posted November 13, 2013 Report Posted November 13, 2013 We are a building contractor and need to know if there is any certification or registration required by us before we can install fire door. Can we self certificate our own work or is this done by a different organisation. Quote
Guest Neil Ashdown Posted November 14, 2013 Report Posted November 14, 2013 Hi, There are ways you can train your installers and schemes you can join to enable you to provide evidence of your competence. The Fire Safety Order defines a Competent Person as 'someone with sufficient training and experience, qualifications and knowledge to be able to implement fire safety measures (some or all) in a building'. www.fdis.co.uk - The Fire Door Inspection Scheme provides on-line education for all who work with fire doors. There are two levels, the Diploma in Fire Doors and Certificated Fire Door Inspector. www.firas-database.co.uk - FIRAS is a third party accredited installer scheme and they offer training to installers and periodic audits of member companies installation work. If you don't require training but require a Competent Person to sign off your installation work you could appoint a CertFDI fire door inspector at www.fdis.co.uk/inspector Regards, Neil. Quote
Guest TomPr Posted December 2, 2013 Report Posted December 2, 2013 Hi. I've done a loft conversion and need to upgrade about eight doors to fd20. I'd like to do it myself and get the reqired certificate for the Building Control Officer. The Officer cant tell me how to do it but gave me a website. But the website just wants to do the job themselves which I'm reluctant to let them do. Quote
Tom Sutton Posted December 2, 2013 Report Posted December 2, 2013 You could search the web with "upgrading fire doors" and see if any suitable links are found. Quote
Guest JamesCoc Posted December 14, 2014 Report Posted December 14, 2014 We manage blocks of flats with communal areas. A recent Fire Risk Assessment has identified some minor repairs required to intumescent strips that have been painted over, and minor adjustment to the fitting of some doors. Can we use a competent Joiner for this work albeit that he isn't qualified specifically to do BS476 and BS8214 work. Thanks. James Quote
Tom Sutton Posted December 15, 2014 Report Posted December 15, 2014 Providing you are not going to modify the doors and it is purely maintenance then a competent joiner should be more than adequate. Quote
Guest Ole Posted September 26, 2017 Report Posted September 26, 2017 Does anyone one know all the names of 3rd party accreditations for fire door installers. So far I found FIRES, TRADA, BRE & IFC. Also is FENSA contractor ok to use to install an FD30 fire door? Quote
Neil Ashdown MAFDI Posted September 26, 2017 Report Posted September 26, 2017 The important thing is that the installer is competent. Ask the installation company what reference documents they use and what standards they work to when installing fire doors and also what training the installers have received. Personally, if they are not familiar with 'BS 8214 : 2016 Timber based fire door assemblies Code of practice' and the GAI / DHF guidance document 'Hardware for Fire & Escape Doors' I would not employ them. Some clients are now requesting, as a condition, that the installation company provides a report by a competent third party confirming that the fire doors have been installed correctly. Third party accredited installation companies have their quality management systems audited periodically, their managers receive training and some of their work is subject to inspection by the scheme provider. FENSA, to the best of my knowledge, do not operate a third party certification scheme for installation of fire doors. Their have been numerous reports about poor quality and non compliant fire door installation work so remember, competence is king. Quote
Guest Fire Door Certificates Posted November 7, 2017 Report Posted November 7, 2017 Can someone please advise if each fore door within a building should have its own separate certificate of compliance or is it acceptable to have a type certificate . I have approximately 2500 fire door-sets installed in my building and I need to be confident that we are in full compliance with our statutory duties / obligations. Quote
Neil Ashdown MAFDI Posted November 9, 2017 Report Posted November 9, 2017 You don't say if you are referring to new fire door installations or existing ones and this makes a difference because: 1) If you have had new fire doors installed the installer should be able to provide you with fire and smoke performance certification for the products used to make up the fire door assembly. The standards applying to fire and smoke performance for fire door components are BS 476 part 20/22, BS476 part 31.1 , BSEN1634-1 and BSEN1634-3 (the list here is not exhaustive). He should also be able to provide confirmation that the doors have been installed in accordance with the door manufacturers instructions and BS8214:2016. 2) If you mean existing doors then you must refer to Article 17 of the Fire Safety Order ( http://www.legislation.gov.uk/uksi/2005/1541/article/17/made ) to ensure that fire safety devices (this includes fire doors and escape doors) are subject to a suitable system of maintenance and are maintained in an efficient state, in efficient working order and in good repair. With regard to your question about separate certificates or one certificate for all doors, this would depend on numerous factors, not least, on whether the fire doors are all the same product with identical components. My advice is to seek advice from a Certificated Fire Door Inspector at www.fdis.co.uk/inspector He or she is the Competent Person as referenced by the 2005 Fire safety Order. Hope this helps, Neil. Quote
Aniend81 Posted November 22, 2017 Report Posted November 22, 2017 Neil thanks a lot! This surely helps. I am going to analyze the link that you've given more carefully! thanks for answering that and for the detailed explanation. I can see that you know about https://musclegurus.to/forum/anabolic-steroids/steroid-cycles very good so I thought, do you mind if I am going to have some questions to ask you, please? thanks a lot! Quote
Guest Kevin Posted February 20, 2018 Report Posted February 20, 2018 As an installer do i need to be certified to install fire doors? I am FENSA registered but when i phoned them i was told i didn't need personal certification, the door does and i need to follow the suppliers fitting instructions. Quote
Neil Ashdown MAFDI Posted February 20, 2018 Report Posted February 20, 2018 Hi Kevin, I am assuming here we are talking about timber based fire doors? The important thing is that the fire door is fitted in strict accordance with the manufacturers installation instructions. Depending on the manufacturer those instructions may make reference to the requirements of BS 8214 the Code of practice for Timber based fire door assemblies. If so you will need to refer to both documents (the British Standard and the manufacturer's instructions) for component selection and installation criteria. If the fire door leaf is certificated under the scope of the BWF-Certifire scheme you will find a label on the top edge of the door leaf. On this label you can find the manufacturers contact details and a number with the prefix 'CF'. If you go to https://www.warringtoncertification.com/certifire/technical-schedules.html you can find the data sheet applicable to that CF number. That data sheet will provide information about component compatibility and installation requirements. The data sheet and installation instructions may not provide information about installation of cold-smoke seals so it will be helpful to get information from the Intumescent Fire Seals Association website at http://www.ifsa.org.uk/documents/ FENSA are correct there is no legal requirement for certification for the installer but evidence of fire (and smoke) performance is required for the products. In England and Wales the 2005 Fire Safety Order refers to the 'competent person' so as you are installing fire safety devices you may have an obligation under the scope of fire safety law as that competent person. Competent Person is defined at the HSE website http://www.hse.gov.uk/involvement/competentperson.htm Finally, training for fire door installers and maintainers is available and so is worth some consideration. Hope this helps, Neil. Quote
Guest Daryl Posted March 23, 2018 Report Posted March 23, 2018 Hi Neil, I was hoping you could help me too, Does the no legal requirement for certification for installers apply in Scotland? The company I work for is looking to install fixed glazed fire screen our main contractor has sourced. I am struggling to find information online confirming that it is or is not required for us to be a certified installer. So i was hopping you could point me in the right direction Quote
Neil Ashdown MAFDI Posted March 26, 2018 Report Posted March 26, 2018 You don't say if the work you refer to is subject to building regulations or whether the client has stated any requirement for the materials or installation to be third party certificated. The Building Regulations in Scotland 'Technical Handbook: Fire' can be found at http://www.gov.scot/Resource/0052/00521763.pdf The regulations describe third party certification schemes but do not make it a mandatory requirement. However, the client may specify that the work must be carried out using a third party certificated glazing system or installed by an installer belonging to a third party certification scheme. Whatever, the requirements in terms of products and installation, the work must be carried out competently and helpful guidance is available from the Glass & Glazing Federation at http://www.ggf.org.uk/groups/fire-resistant-glazing-group/fire_resistant_glazing_best_practice_guide Quote
Guest mark Posted September 11, 2018 Report Posted September 11, 2018 I work for a fm company and we have 12m fire door inspections. do we a a engineer need any certificates/training to carry this out? Quote
AnthonyB Posted September 15, 2018 Report Posted September 15, 2018 Yes, you need to be able to demonstrate competency - with up to 52 individual points to correctly check some form of training is usually in order! Quote
Guest Engineer Posted October 11, 2018 Report Posted October 11, 2018 Hi I have a timber fire door where I work that needs new glass. Can I install or would a trained person need to do this Quote
Tom Sutton Posted October 12, 2018 Report Posted October 12, 2018 All glass types are available on a supply-only basis but it must always be fitted into a frame that has the appropriate test evidence, using the glazing seals and bead types that are approved for that particular glazed system. Competent persons who have the relevant specialist knowledge must always carry out the installation of the glazed system, according to the construction and components given in the accompanying evidence of performance. Fire-resistant glass must only be used as part of an appropriately approved glazed system. Check out http://www.ggf.org.uk/?geodir_search=1&stype=gd_place&s=Fire+Resistant+Glazing&sgd_placecategory[]=&snear=&sgeo_lat=&sgeo_lon= Quote
Neil Ashdown MAFDI Posted October 12, 2018 Report Posted October 12, 2018 Hi Engineer, You say the door needs new glass so I am assuming its already glazed but that the glass is damaged. If so make sure the new glass is suitably fire resistant and that the repair work is completed using the correct gasket materials, hardwood bevelled glazing beads with pins/screws of the correct dimensions at the correct centres and angled towards the centre of the door core thickness. This document may be useful to you https://www.ggf.org.uk/publications/fire-resistant-glazing-publications/guide-best-practice-specification-use-fire-resistant-glazed-systems/ Do not attempt to cut an aperture for glazing to a fire door without first seeking expert advice. Quote
Guest Greig L Posted November 30, 2018 Report Posted November 30, 2018 I have received a letter from my landlord that the front entrance door of my flat (which is a fire door) needs a 'self-closing device' and replace smoke/fire seals - following a fire risk assessment. I have checked my lease: the demise includes the door and frame. I have been told that I must provide proof the work was carried out by someone 'suitably qualified' such as 'accredited fire door maintainer/installer' to ensure the correct closer and seals used that is compatible with the door set and installed correctly. I understand the importance of fire doors but I dont think I need to pay someone to carry out this simple work that I can do myself. Are there any laws/regulations that restrict me from carrying out work? or is it just best practice? As I understand an accredited person is only required to avoid invalidating the certification of the door set - I understand that my front door is not certified. Greig Quote
AnthonyB Posted November 30, 2018 Report Posted November 30, 2018 The law requires merely competence. Using accredited providers are an easy way of showing this but not the only way. Envirograf make a lot of retro fit strips and seals for existing notional fire doors that have test certification and can provide advice and fitting instructions. Whether your freeholder would accept this is another matter and you may need to take legal advice on their rights under the lease to require so specific an installer requirement. Unless the doorset is suitable for simple products such as the adhesive seals and so work cutting out of the door or frame may be required I'd consider it preferable to use a specialist - this could be the accredited providers (preferred) or a contractor who can prove competence (some may have recognised training in fire door work but not gone to the expense of being in a formal accreditation scheme) Quote
Neil Ashdown MAFDI Posted December 1, 2018 Report Posted December 1, 2018 Any competent person working on fire door repairs, maintenance, upgrades or installation should have sufficient understanding of fire and smoke separation issues. I would expect that person to, at the very least, have experience working on fire doors, be familiar with 'BS 8214 the code of practice for timber fire door assemblies' and the 'code of practice for Hardware for Fire & Escape Doors'. Quote
Guest Sam jones Posted January 2, 2019 Report Posted January 2, 2019 Hi can any body help me regarding becoming a fire door install and what qualification I should be looking at getting so I can install fire doors and give certifation I have been installing doors for year and also fire doors to bs8214 2016 but the job I am working on require a fully qualified fire door install to carry out the work. Quote
