Guest Trigsta
Hi
I am the landlord of a two story, two, 2 bed flats
Flats are owner occupied on long leases with freeholder in occupancy.
From what I have read we are therefore non hmo, as more than 2/3rds owner occupied
There is a 10 year battery smoke alarm in the lobby that feeds both flats, the lobby is approx 2m by 2m.
There is then another ten year smoke alarm interlinked in the upstairs flat.
The construction is pre 1991.
Do i need fire risk assesment?
Can i do one myself?
Thanks for any help
I do not fully understand the situation, are you the landlord on behalf of the owner (freeholder) and the Responsible Person of the common area's. However the answer to your questions are, yes you do need a fire risk assessment and yes you can do it yourself, also it does not need to be recorded if you do not employ five or more people.
You need to study the sleeping risks guidance and http://www.firesafe.org.uk to decide what fire provisions you require.
