Guest SadhanaSt Posted October 15, 2013 Report Posted October 15, 2013 Hi I have on of your Kidde Firex Mains Powered Smoke Alarms with Lithium Battery Back-up Product Code: KE4892 Version: Heat Alarm It has started today beeping every 15 seconds. Could you advise what I need to do please. The green light is on Thanks Sadhana Quote
Safelincs Posted October 15, 2013 Report Posted October 15, 2013 Hi Sadhana The green light means you have good power supply, so no issue there. Cleaning out would not help as it is a heat alarm. Lithium re-chargeable means the backup batteries do not need to be replaced. Unfortunately, this sounds as if you will need a new alarm. The new model for this is called KEKF3R by the way. Harry Quote
Evapors Posted December 14, 2013 Report Posted December 14, 2013 I read your post and I think it's very useful post, i like it. Thanks for that... Quote
Guest Glen Posted February 17, 2015 Report Posted February 17, 2015 I have the same issue with this model, green light is on and unit is beeping. The unit has a 6/05/2010 sticker on it. I believe these units have a six year warranty. Can it be replaced under warranty? Quote
