Guest CEdwar Posted September 1, 2013 Report Share Posted September 1, 2013 A landlord of a block of flats is required to make and to keep updated a fire risk assessment in respect of communal stair cases, the only means of escape for 1st & 2nd floor residents. If the staircase has its treads and landings covered with a synthetic material that, on heating, decomposes giving toxic fumes. Should such a latent hazard be recorded in the fire risk assessment ? Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted September 2, 2013 Report Share Posted September 2, 2013 You are correct the landlord has to keep an updated fire risk assessment (FRA) in respect of the common areas and should maintain a low fire risk as possible. However the main concern is the walls and ceiling which should meet a class "O" or class 1 spread of fire, this helps to ensure the escape route maintains a low fire risk. Because this area is a low fire risk the floor covering should never be involved and a bigger danger is bad maintenance resulting in a trip hazard. Because of this it is unlikely it would be necessary to include it in the FRA unless the fire risk is increased as the result of other reasons. Quote Link to comment Share on other sites More sharing options...
