Are curtains after washing still fire retardent?
Guest AndroullaAn
I have a furnished letting with flame retardent curtains that have just been washed in the washing machine. I would like to know if my curtains are still flame retardent or do I have to buy some new ones.
Thank you
Best advice I could find.
Fire-retardant fabrics have been treated with chemicals to lower or limit their ability to burn. You can find fire-retardant curtains manufactured from cotton, polyester, fibreglass, wool and linen. Curtains labelled as permanently fire-retardant, inherently fire-retardant or durably fire-retardant have fire-retardant properties woven into the fabric that will not dissipate with cleaning.
If your curtains bear a label that says they are merely fire-retardant, they have likely been sprayed or coated with a fire-retardant chemical that will gradually wash or wear away. The chemicals used to make fabric flame-retardant can dissolve with both water washing and dry cleaning. If you wash fabric marked flame- or fire-retardant, you will need to re-treat the fabric after washing to restore the fire retardancy.
Instructions
1. Read the label on the curtains. You can usually find the label attached to a seam inside the lining, or near the top or bottom of the curtain panel, inside. The label should contain instructions to tell you if the curtains should be dry-cleaned or may be washed. The label will also tell you the fire-retardant designation of your curtains.
2. Vacuum the curtains to remove dust and surface dirt. Use the upholstery attachment of your vacuum cleaner and move from the top to the bottom of the curtain. This is easiest to do while the curtains are still hanging.
3. Wash washable curtains in cool water with a mild detergent, using a delicate cycle. For large curtains, use a large-capacity washing machine at a coin laundry, instead of your home machine. This will help prevent wrinkling.
4. Dry-clean non-washable curtains. Be sure to let the dry cleaner know that the curtains are fire-retardant.
5. Spread the curtains flat to dry. If you hang them while they are still wet, you could stretch large or heavy curtains out of shape. Hang the curtains once they are dry and steam them lightly to remove wrinkles.
6. Spray or dip curtains labelled fire- or flame-retardant in a product designed to restore fire-retardant properties after washing. Follow the manufacturer's directions for proper application of the fire-retardant treatment.
I fail to mention the relevant British Standard is BS pt 2:2008 Fabrics for Curtains, Drapes and Window Blinds. Part 2 Flammability Requirements - Specifications.
