High Rise flat doormats
Guest Colin Middleton
Our local Council management are enforcing sterile conditions in our high rise block. As part of this is the changing of small doormats usually offcuts of normal
carpet within the flat. In place the Council insist on rubber backed mats.
I would suggest that rubber backed mats, in the case of fire, would give off toxic fumes, possibly worse than the normal household pieces of carpet.
Could a professional Fire Officer give his/her opinion on this. Or is it too trivial to be considered as a risk.
Yours Sincerely Colin Middleton
The doormat will be a very low fire risk and having it rubber backed is more likely to prevent it slipping which could cause a trip hazard.
