Guest Guest123 Posted June 19, 2018 Report Share Posted June 19, 2018 hi. my workplace has recently converted store rooms into offices. these are on a second floor. access is via ground floor door and stairs. once upstairs there are 3 offices, toilets and a kitchen, around 25 ppl. there are no windows at all on this floor. the only entrance in and out is downstairs through one door. Can you advise if we need two fire exits. I feel we do. but am getting nowhere with my place of work Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted June 20, 2018 Report Share Posted June 20, 2018 What you are seeking is a simple answer to a complex question which does not exist, you need a FRA to get the answer which will have to take into account fire alarms installed, travel distances, plus other factors than need to be considered. Check out https://www.firesafe.org.uk/fire-risk-assessment/ and https://www.gov.uk/government/publications/fire-safety-risk-assessment-offices-and-shops Quote Link to comment Share on other sites More sharing options...
Guest BDO Posted September 21, 2018 Report Share Posted September 21, 2018 Hi, I am hoping for some advice. We are a new tenant within a multi-occupied 8-storey building. The building is provided with 2 fully fire protected stairwells leading to ultimate safety on ground. most floors will be one tenant who have access to bot fire escape routes. We are located on the 4th floor which is subdivided into 2 separate offices. We can only access the main fire escape stairwell to the front of the building but cannot access the rear escape without accessing another tenants office, which they do not want to happen. We have around 20 employees in a general office building with no high risk fire areas and are under 18m away from the fire protected stairwell lobby. Is this one exit suffice for our needs or do i need to take anything else into account. Any advice greatly appreciated Quote Link to comment Share on other sites More sharing options...
AnthonyB Posted September 21, 2018 Report Share Posted September 21, 2018 If it's a finished floor height of 11m plus then you should have access to both exits, which if partitioned after current building regulations came into being shouldn't go through another tenants space (it did used to be accepted) Quote Link to comment Share on other sites More sharing options...
Guest Advice needed Posted January 1, 2019 Report Share Posted January 1, 2019 Hello, I am in the process of moving into a barn which is being converted into an industrial unit. It is 32m long x 9m wide approx and there is a large industrial sliding door at the front of the unit. I believe due to the length of the unit I would need a fire escape at the back of the unit? It is being used for powder coating and fabricating, 5 employees. The walls are solid concrete and quite thick - so a fire escape door is going to cost £1000 to put in. My question is - would I be liable to the cost of putting in the fire escape door or would that cost fall on the landlord or would it be a shared cost? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted January 3, 2019 Report Share Posted January 3, 2019 You are the Responsible Person (RP) under The Regulatory Reform (Fire Safety) Order 2005 and subject to articles 8 t0 22 but it is not totally a fire safety matter it is a legal matter and would depend on the contents of your tenants agreement you should check it out with your solicitor to find out what the landlord is responsible for. Quote Link to comment Share on other sites More sharing options...
Guest Need Advice Posted June 30, 2019 Report Share Posted June 30, 2019 Hello We work in an office inside a warehouse I work in office with 2 x 43" monitors and 16 monitors and 6 PC's , usually there are 5 people in the room , at worst they can be 5 working and upto 8 other people standing , if there are work issues We have 1 fire door and 12 glass windows , that cannot open , the fire door lead to a small corridor , there they are 3 sets of more fire doors , and also the fire alarm button and the fire extinguishers , there are also electrical outlets If there was a fire door in the corridor , we have no means of escape , no way to reach the fire extinguishers and no way to press the fire alarm button Is this allowed Thank you Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted July 3, 2019 Report Share Posted July 3, 2019 I cannot be definitive without surveying the situation, but appears the corridor you speak of, is a means of escape route of comparative safety, that eventually will lead to ultimate safety and consequently will be a very low fire risk. Assuming this is correct and the travel distance is within the required limits, then it should be satisfactory. Quote Link to comment Share on other sites More sharing options...
Guest Guest Karen Posted July 22, 2019 Report Share Posted July 22, 2019 Karen, Is it legal to have only one exit to a flat if that exit is through the kitchen Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted July 23, 2019 Report Share Posted July 23, 2019 If the kitchen is an enclosed habitable room in most cases the answer would be, it is not acceptable but to give a definitive rely you would need to give more information including a layout, preferably have it surveyed by a fire risk assessor. Quote Link to comment Share on other sites More sharing options...
Guest Guest Stephen Posted November 13, 2019 Report Share Posted November 13, 2019 Tom Firstly thank you for hosting and answering - this has been an incredibly useful reference. I wanted to ask about disabled access and egress in a restaurant premises. There is only one level entry (the main doors). There are two other fire exits but neither is level amd would require step navigation. Does a restaurant need to allow for more than one for one accessible fire exit. Building dimensions are 20m x 10m. Capacity upto 100 covers. Grateful for advice and thanks! Quote Link to comment Share on other sites More sharing options...
Tom Sutton Posted November 13, 2019 Report Share Posted November 13, 2019 What is the direction of opening of the doors and the widths? Check out the appropriate guides including for disabled persons in https://www.firesafe.org.uk/regulatory-reform-fire-safety-order-2005/ . Quote Link to comment Share on other sites More sharing options...
Guest Protect UK Posted October 1, 2021 Report Share Posted October 1, 2021 I am a lone worker in a very small L shape office. We have one entrance but no fire exit. The building has cladding, my work desk is close to the entrance, but further down is the kitchen and toilet. If I was in the kitchen or toilet and a fire broke out at my desk I would be stuck as there’s no fire exit. is there a legal requirement for my employer to have this corrected? Quote Link to comment Share on other sites More sharing options...
green-foam Posted October 2, 2021 Report Share Posted October 2, 2021 Guest Protect UK has made a duplicate post which you can see/reply to if you Click here Quote Link to comment Share on other sites More sharing options...
