How to fit door closers on double doors?
Guest SarahRidd
Guest SarahRidd
Quick query: at my local Cricket Club we have a double set of fire doors that we need to use for access from the outside and egress from inside, but players are leaving the door open as there is no closer - therefore causing a security issue.
What fire door closers can we install to make sure that the doors close in sequence and latch? Can we vary speed and force?
Tanks
Sarah
  • 2 years later...
Guest Robbi
I NEED TO HAVE ONE SIDE OF DOUBLE SWING DOORS FITTED AT A WORKPLACE THROUGH TO A FRONT LOBBY, WILL A MEDIUM DUTY FIRE-DOOR CLOSER DO?
The other side is already fitted with a working door closer and looks like a light to medium duty one
Door closers are designated according to BS EN 1154 1997 and the door width and mass in Kg defines the power size, also needed, is it a fire door.
Consequently you need to know the width, mass and is the door a fire door to determine the power size required. Most retailers should be able to provide the test certificate and using the BS EN 1154 you can determine the power size required.
The third digit defines the power size and can be two digits, from to.
