Guest Shawntre Posted November 19, 2012 Report Posted November 19, 2012 I need to reset the electronic passcode for the Phoenix Centurion 1262 fireproof safe, as a member of staff saw me using the passcode today. Can anybody help? Quote
green-foam Posted November 20, 2012 Report Posted November 20, 2012 To change the code you should follow the instructions below: 1. Press button C 2. Enter the current passcode (this may be the factory default 1,2,3,4 or a previously set user code of 4-16 digits) 3. Press button # (a melody will sound to confirm your code) 4. Turn the knob to open the lock 5. With the lock open, press the # button 6. Enter the code from step 2 (the default factory code 1,2,3,4 or previously set user code) 7. Press the # button 8. Enter a new 4-16 digit code 9. Press the # button. Your code is now set to the one entered in step 8 Quote
Guest Posted March 7, 2016 Report Posted March 7, 2016 Got safe have no codes safe is open but locks are out an can't close door Quote
Guest Posted March 8, 2016 Report Posted March 8, 2016 Hello Please see below a copy of the instructions for the electronic lock:http://www.safelincs.co.uk/templates_safelincs/files/datasheets/1779_SS1620E-Electronic-Lock-Instructions.pdf If you refer to the second page and the section that says "setting a new personal code" this explains how to change the code. I hope this helps Quote
Tom Sutton Posted September 6, 2016 Report Posted September 6, 2016 If you do not have the present code you will not be able to change but you could contact the manufacturer and see if they can help, there may be a way to reset to factory code. Quote
Guest Re set code Posted November 14, 2016 Report Posted November 14, 2016 Inside the safe is a red button can you re set a new code from there not knowing the original? Quote
Safelincs Posted November 14, 2016 Report Posted November 14, 2016 Which model safe do you have? We can then check out the manual. Harry Quote
Guest bob Posted February 28, 2017 Report Posted February 28, 2017 Hi I have just bought a Phoenix Data Combi DS2503E from the local tip with a broken handle and they said the code was 2016 and they unlocked it before I took it . I have it home and now it will not open is there a delay on it or something im doing wrong thanks Quote
Safelincs Posted February 28, 2017 Report Posted February 28, 2017 Hi Bob you need to make sure that the batteries are replaced in the front cover should they be low. Here also the lock instructions for the Phoenix Data Combi fire safe. If the standard factory code shown does not work you will need to get an original invoice to prove ownership to Phoenix before they issue a master code which is probably not possible in your case. Harry Quote
Guest Maxine Posted December 28, 2018 Report Posted December 28, 2018 Hi I've just started a new job and need to change the office safe combination. We have a Phoenix Fire Fighter 0421, can anyone please give me instructions. Thanks Quote
Safelincs Posted December 28, 2018 Report Posted December 28, 2018 Hi TO SET THE PERSONAL CODE 1. Press the # button. 2. Press the green code change button located on the back of the safe door 3. Enter your personal 3 to 6 digit code and press # button to set. 4. The lock will emit a tone and the LCD will display IN. to confirm the new code. 5. To change the code follow the same procedure with the door and lock in the open position. This lock can be programmed with an 8 digit master code; which cannot be removed, but can be edited. Consider carefully if you require this function before entering a second code. TO SET THE MASTER CODE 1. Press the # button 2. Enter 0,0 3. Press the green code change button. 4. Enter the selected 8 digit master code. 5. The lock will emit a tone and the LCD will display IN. to confirm the master code. test before you close the door Harry Quote
Guest Stephen Posted July 23, 2020 Report Posted July 23, 2020 When i enter the code the LED says opened, but the safe is closed. I am locked out, any ideas? Quote
green-foam Posted July 26, 2020 Report Posted July 26, 2020 It may be the batteries are nearly flat and are only able to power the LED display but too flat to open the bolt. Have you tried changing the batteries? Quote
Guest Alex Posted October 30, 2021 Report Posted October 30, 2021 Hi , we have large Phoenix Fireproof cabinet. It was not used for the last 2 years due to COVID , since we worked from home. Unfortunately the combination and other documents were lost. What would be the procedure to recover the code? Quote
green-foam Posted November 2, 2021 Report Posted November 2, 2021 You will need a receipt/proof of purchase to obtain a "Master code" (That may or may not work, depending on model) If you do not have this, you will have to call a locksmith. Quote
