Tom Sutton Posted July 22, 2022 Report Posted July 22, 2022 Why can't you open the windows in the warm weather? Quote
Guest Nathaniel Posted August 19, 2022 Report Posted August 19, 2022 At a place of business I work at, the staff entrance has always been designated as a fire exit in all the years I have been there. To enter when premises is closed to the public, we call a number and a manager let’s us inside. To exit, we press a button and the door opens for us to leave. There is signage on the outside of the door saying it is a fire exit. Recently management have decided it is not a fire exit and is being manually locked whilst the building is still occupied. Is this legal? Quote
Tom Sutton Posted August 20, 2022 Report Posted August 20, 2022 Without a survey it is impossible to say what MoE is required, it all depends on the layout of the premises. Quote
AnthonyB Posted August 21, 2022 Report Posted August 21, 2022 On 19/08/2022 at 09:58, Guest Nathaniel said: At a place of business I work at, the staff entrance has always been designated as a fire exit in all the years I have been there. To enter when premises is closed to the public, we call a number and a manager let’s us inside. To exit, we press a button and the door opens for us to leave. There is signage on the outside of the door saying it is a fire exit. Recently management have decided it is not a fire exit and is being manually locked whilst the building is still occupied. Is this legal? Not without a fire risk assessment that is suitable and sufficient and by a competent person justifying why means of escape is still acceptable without it, usually based on the guidance here: https://www.gov.uk/government/collections/fire-safety-law-and-guidance-documents-for-business Quote
Guest david Posted December 8, 2022 Report Posted December 8, 2022 can someone help i live in a warden controled building and i have to carry a 15kg battery out to my car for my boot scooter now at the side of my door there is a fire exit which i have been using for the last 3 years to carry my battery and shopping back into my flat. due to being disabled i can,t walk the long way round, yet i,ve been told i can,t use the fire exit anymore to exit the building. can you help Quote
Mike North Posted December 12, 2022 Report Posted December 12, 2022 This is a building management issue not a fire issue Quote
Guest Kernow Posted January 18, 2024 Report Posted January 18, 2024 It is my understanding that a final fire exit door can be used as an entry if is has the correct external unlocking device, if the door only has the quick release push bar or push pad then they should only be used for exit when needed and not for regular egress from a building Quote
Guest Roger Posted March 17, 2024 Report Posted March 17, 2024 A single story club with a fire exit hallway approximately 14 ft long 6ft wide.are we allowed to hang pictures on the walls. Quote
Mike North Posted March 18, 2024 Report Posted March 18, 2024 All depends on what they are made of and size and is there an alternate escape? You really need a fire risk assessment Quote
Lyledunn Posted March 23, 2024 Report Posted March 23, 2024 It is often done in such premises and probably without significant detriment to fire safety. Where done, I would agree with MN above and also say frames should be secured with mirror plates or similar to prevent them being dislodged. However, it doesn’t seem logical for Building Regulations to require fairly stringent spread of flame characteristics for walls in escape routes only for someone to go plastering them with all sorts of detritus. Quote
Guest Guest A Posted October 21, 2024 Report Posted October 21, 2024 Does a door that is the only entry and exit door to a flat need to be a fire door? The flat is on the second story and is accessed by fire escape metal stairs. Thanks Quote
