Guest Alice Posted August 30, 2011 Report Posted August 30, 2011 Hi, Can you use a softwood door lining with a hardwood fire door? Would that apply to safety regulations or not? Thanks Quote
Tom Sutton Posted August 30, 2011 Report Posted August 30, 2011 Fire doors should be installed as fire door sets which means the door and frame which are tested as a unit. A fire door blank fitted in a standard frame will not give a guaranteed standard and would be considered a nominal fire door which may not be accepted by the enforcers. (Fire and Rescue Service) Quote
