Guest Gunj Posted August 30, 2011 Report Posted August 30, 2011 I have a property that I let out to students. i am refurbishing the house and I would like to paint the fire doors as they have some marks on them. The fire doors are plain wood with no paint on. Can I use any paint to paint the doors or do i need to use a special paint? Many thanks, Quote
Tom Sutton Posted August 30, 2011 Report Posted August 30, 2011 Fire door leaves are generally not required to provide a specific surface spread-of-flame barrier, and may therefore be decorated as desired. There is no evidence to suggest that over painting of intumescent seals has any detrimental effect on the ability of the seals to perform efficiently. There are some benefits in over painting the seals as they are less likely to absorb atmospheric moisture. However, there are limits on how much paint can be applied without there being a risk of the seal being rendered inoperative. It is recommended that over painting be limited to a maximum of five coats of conventional oil-bound paint or varnish. When preparing a frame for redecorating, the use of heat or chemical strippers should be avoided if intumescent seals are incorporated. If seals are damaged by either of these processes, they should be replaced. If glazing beads have been painted with intumescent paint, it is essential that they be repainted with a similar paint. Quote
Guest Gurps Posted August 16, 2014 Report Posted August 16, 2014 I wonder if you can help me with a question? If smoke seals on fire doors have been painted on and are not soft. Will they need replacing or are they fine? Thanks Quote
Tom Sutton Posted August 17, 2014 Report Posted August 17, 2014 Fire door leaves are generally not required to provide a specific surface spread-of-flame barrier, and may therefore be decorated as desired. There is no evidence to suggest that overpainting of intumescent seals has any detrimental effect on the ability of the seals to perform efficiently. There are some benefits in overpainting the seals as they are less likely to absorb atmospheric moisture. However, there are limits on how much paint can be applied without there being a risk of the seal being rendered inoperative. It is recommended that overpainting be limited to a maximum of five coats of conventional oil-bound paint or varnish. When preparing a frame for redecorating, the use of heat or chemical strippers should be avoided if intumescent seals are incorporated. If seals are damaged by either of these processes, they should be replaced. Quote
Guest JeanHar Posted December 3, 2014 Report Posted December 3, 2014 If you want to paint your fire doors, does the paint have to be fire retardant or can I use gloss? Quote
Tom Sutton Posted December 3, 2014 Report Posted December 3, 2014 Decoration Fire door leaves are generally not required to provide a specific surface spread-of-flame barrier, and may therefore be decorated as desired. There is no evidence to suggest that overpainting of intumescent seals has any detrimental effect on the ability of the seals to perform efficiently. There are some benefits in overpainting the seals as they are less likely to absorb atmospheric moisture. However, there are limits on how much paint can be applied without there being a risk of the seal being rendered inoperative. It is recommended that overpainting be limited to a maximum of five coats of conventional oil-bound paint or varnish. When preparing a frame for redecorating, the use of heat or chemical strippers should be avoided if intumescent seals are incorporated. If seals are damaged by either of these processes, they should be replaced in accordance with manufacturers instructions. If glazing beads have been painted with intumescent paint, it is essential that they be repainted with a similar paint. Quote
Guest David Posted April 29, 2022 Report Posted April 29, 2022 My mother has a flat with fire doors. They have been painted but smell very toxic even after a year after moving in. If painted with fire door paint could this be dangerous to her health? Thanks in advance Quote
Tom Sutton Posted June 8, 2022 Report Posted June 8, 2022 Contact the manufacturer of the paint. Quote
