Guest IanW Posted November 5, 2012 Report Posted November 5, 2012 i am looking for information of fire ratings on timber, section size required, density for 30min and 60 mins. Quote
Tom Sutton Posted November 6, 2012 Report Posted November 6, 2012 To my knowledge it doesn't exist, different timber will char at various rates hardwoods slower than softwoods and you may find such tables on the speed of char, but that is all. Check out http://www.trada.co....fire/index.html and http://www.woodspec.ie/sectionadesignguidance/a5fireperformance/ Quote
Guest SamBuck Posted June 10, 2014 Report Posted June 10, 2014 I am looking to get a fire certificate for a trade show that I am exhibiting at for our rail system. The supports of the clothing rails are made from 12mm Plywood, that will have design spray painted on the front and rear face of the plywood. I'm wondering how do i go about getting a fire safety certificate for it? Quote
green-foam Posted June 10, 2014 Report Posted June 10, 2014 To get a fire certificate the item in question has to be tested to destruction by an independent testing company. But they usually test things like walls, windows, ducting systems etc, are you sure its a fire certificate you are looking for. Quote
Tom Sutton Posted June 11, 2014 Report Posted June 11, 2014 Sam what are the organisers of the trade show asking for is it a level of surface spread of flame or combustibility or what. Quote
