Minimum dimensions of fire exits
Guest LaurPar
Good afternoon,
I have an enquiry about a mesh fire exit door on a roof, the measurements are 1,500mm high x 500mm wide. I wondered what is the smallest width and height a door can be?
Kind regards
Lauren
Hello Lauren
For fire exits, the width is the most important factor, and this is determined by the number of people who are likely to be using a particular exit. Current Building Regulations (Fire Safety, Approved Document B, 2010) specify a minimum width of 750mm for a final exit door, to accommodate a maximum of 60 people. As a matter of interest, the minimum standard dimensions for a fire escape roof window (as opposed to a door) are 660mm by 1180mm. Height wise, your door is OK; but it is too narrow for its purpose.
If it is subject to the building regulations then Approved Document B Vol 2 Building other than dwelling houses then check out page 37. It states for 60 or less persons, 750 mm width, normal door height, with some provisos. However in an existing premises risk assessment applies and it depends on the number of persons, the speed of exit required, the agility of those involved and a full assessment of the risk. For instance if it is for a couple of service engineers working in a plant room it could be acceptable but for an office full of office workers not acceptable. It is up to the responsible Person.
  • 5 months later...
Guest DianeLan
Please can you tell me what the minimum amount of space is required to access a fire exit?
E.g. How much space should be kept between two desks if access to the fire escape is between the two desks?
The minimum width would be the width of the fire exit but the more space the better, because of bunching up, which happens when numbers of people attempt to pass through the door at once.
  • 3 months later...
Guest JohnDen
Hi All,
Please could you confirm the minimum width of access required for a small comms room with 2 cabinets approximately 11 meters square? The room is only likely to have 2 people in at any time. Is this still 750 mm?
kind regards,
John
  • 3 years later...
Guest Jon r
What is the minimum height required for glazed hardwood fire doors entrance.  We are in a building working on a new gym the height of the installed door is 1900 mm high we think it should be 2040 can you please shed some light on this?
many thanks jon r
The standard height of doors in the UK is 1981mm, except the most commonly used doors in Scotland and Europe is 2040mm. However the height is not a major concern the width is more important in fire safety and the major problem with the height is reducing standard fire doors to fit small frames. This is because you are limited how much you can remove from the top and bottom of fire doors and each one is different you need to read the manufacturer's documentation to find out.
  • 10 months later...
Guest Lucia
I live in the block of 140 apartments with 3 double door fire exists. However one of them can’t be opened as double door  as is broken. Manager of the building told me that this doesn’t need to be fixed .
Check the fire risk assessment. Is this an exit at ground level to open air? Depending upon the location and distribution of the exits and any stairs and if the premises are stay put then there is a slight possibility the exit is for accommodation  only and not required for escape - but I would want to see how they came to this decision.
  • 5 weeks later...
Guest CeePee
We have an office building which has a fire exit out onto a shared access driveway which one our neighbours parks on - sometimes parking over the width of the door (not sufficiently close to prevent the door from opening fully, but certainly in front of) - is there a minimum distance from the fire exit to any further obstruction?
