Guest Lindseys Posted August 17, 2011 Report Posted August 17, 2011 Hello, I am enquiring for some support and guidance requiring minimum hallway (exit corridor) widths for a residential flat. I have recently received a note from a neighbour objecting to my bicycle in our hallway which is flush against the wall (I turn the handlebars every night to not obstruct). I believe according to my own egress calcuations and research concerning fire code law - on the assumption of a 40 flow rate and 2 min evacuation time for 5 occupants the minimum width is 624 mm. Even with the current bicycle position the width that remains is greater than 1000 mm and does not impede or obstruct fire exits or any health and safety concerns. I am looking for some support to ensure that I've done these calculations correctly before writing back a formal letter to the council. Thanks for all your help in this process! Quote
Tom Sutton Posted August 17, 2011 Report Posted August 17, 2011 What happens if the bike is knock over in the panic to escape what happens to width of the corridor? If this happened it would cause a serious obstruction and any calculations would be irrelevant. Quote
