I saw your helpful website and thought you may be able to offer me some advice on which sticker to use over the lens of my replacement safety lamp.
I am a Registered Electrician who is replacing a safety lamp at a nearby club which has been vandal damaged.
The location of the light is outside immediately above the main entrance door to the club. The existing damaged light did not have a sticker on the lens but I believe it should have had!
The 2 labels supplied with the new Extera Lamp I've just purchased, are shown in the attachment.
I think the bottom sticker is the one to use - any advice please??
If the existing light is outside of the building, it is not a fire exit sign but an emergency light to provide light in the immediate area in front of the door in case of a power cut. It does not require a sticker.
In general (not applicable in this case): you would need three of the four elements you were supplied:
1) A door symbol
2) The little man running towards it
3) A directional sign between man and door pointing to your actual escape door
