Guest Chrisc
Is there a minimum amount of space that should be around a fire door, in a room that holds 25 people?
Its a matter of common sense. Are there an problems under normal situations, can the door open fully so the opening is not restricted and if there is any doubts a fire evacuation drill should resolve the the matter.
