Guest Andy F
I have a customer who wants a loft conversion. Hallway doors are original and 44mm solid wood. They have a glazed panel. Can that panel be replaced with fire regulated glass and still meet regulation
If the existing glazed door in question is suitable to be used as a fire resisting door, then the existing non-FR glass could most likely be replaced with a fire rated glazing system. But be sure to use, or at least consult, a competent specialist in regard to this work to ensure compliance.
