shula Posted March 3 Report Posted March 3 Hi Does anyone have experience of dealing with doors like these? set back in a 200mm surround We'd like to change for certified doors and add an exterior frame. I can't find any example of this - is it a viable idea. New door will be rebated and lined with fire brush etc and the frame will go in the surround close to the door covering part of the door. We need about 120 so can be made to measure. Quote
shula Posted March 3 Author Report Posted March 3 Hi again - Finally managed to reduce file size so you can see an image of the door surround. What are your thoughts on a new door frame against the door which opens inwards? Hope this makes the position clearer? We need about 120 so new door and frame can be bespoke. Thanks Shula IMG_5762.small jpeg 2.pdf Quote
