Is Souda fire foam suitable for a head of wall fire retardant ?
It's not much use on it's own for many things. If you check the manufacturer's test certification you will find it's only good for small linear gaps of up to 15mm high x 85mm deep between walls and floors or similar gaps between a door frame & wall
https://www.soudal.co.uk/sites/default/files/soudal_api/document/F0041630_0001.pdf
https://www.soudal.co.uk/sites/default/files/soudal_api/document/F0041634_0001.pdf
If used with a fire blanket and intumescent mastic capping it can be used for some penetration seals
