Bob B Posted October 10, 2024 Report Posted October 10, 2024 A multi-occupied office building comprising ground and 4 upper floors. Mostly three companies per upper floor and exiting into the lift lobby, and from there, the staircase enclosure. Some of the companies have glass doors - single or double. No intumescent strips or cold smoke seals are evident. No markings were found on the doors or glazing which indicates any fire resistance. Its quite possible that the individual company has fitted the entrance doorsets retrospectively as some of the other companies have a traditional wooden fire doorset - in a traditional wall. An 8mm gap exists in the centre of one set of doors. What does the panel think? Quote
Neil Ashdown MAFDI Posted October 15, 2024 Report Posted October 15, 2024 It would appear that the doors you describe are most likely not fire resisting doors. Has a fire risk assessment been carried out? Are these doors considered adequate for the purposes of fire protection? Quote
Bob B Posted October 18, 2024 Author Report Posted October 18, 2024 On 15/10/2024 at 05:42, Neil Ashdown MAFDI said: It would appear that the doors you describe are most likely not fire resisting doors. Has a fire risk assessment been carried out? Are these doors considered adequate for the purposes of fire protection? Hi Neil, Thanks for your response. They don't comply and I've recommended that they be replaced by certificated fire doorsets. There are predominately glass doorsets available which comply with current regulations. The glazing is held in a metal frame and have the intumescent strips and cold smoke seals fitted. Upon further investigation, it would seem that the building has recently been completely refurbished and I suspect the the tenants have been allowed to chose the entrance doorset to their particular premises - with no thought as to whether they are suitable or even consulting Building Control. Some tenants traditional timber doorset comply, but the few glass doorsets obviously do not. Quote
