September 25, 20242 yr comment_44836 Hello My daughter has just moved into a halls at university, on the ground floor. She has safety restrictor on the window, which I presume is to stop intruders. But I am concerned how she would get out in the event of a fire, if she could not get out the door. The window is double glazed so would be hard to break. Any advice would be appreciated. Many thanks Nicky Report
September 30, 20242 yr comment_44927 Sorry I have re read your entry. It's it's classed as an escape window it should meet the following requirements: Height: The window should be between 800–1000 mm from the internal floor level, so that it's safe to climb out Size: The clear opening should be at least 0.33 square meters, and at least 450 mm in both width and height Safety: The window should lead to a safe place Report
