Will Posted September 13, 2024 Report Posted September 13, 2024 Is plastic trunking with fire clips still acceptable in a small commercial install? Quote
AnthonyB Posted September 17, 2024 Report Posted September 17, 2024 Will the cables remain mechanically fixed to the wall or ceiling by metal fixings after the PVC trunking has melted and failed? If so, then yes. If the cable is only clipped to the trunking and will sag & fall with it then no. Quote
