Eric90 Posted July 14 Report Share Posted July 14 Two fire doors within a two storey building were fitted a number of years ago, a recent fra found these doors had the top edge taken off exposing the core. Am I right in saying that these need replacing as works to add a hardwood strip are not permissable which is what the clients deems is an acceptable solution! Quote Link to comment Share on other sites More sharing options...
AnthonyB Posted July 15 Report Share Posted July 15 Depends - repairs are possible, especially where a notional door would be accepted in the FRA. A competent fire door inspector (one of which is a regular contributor to the forum & should answer at some point) will be able to advise on the viability of repair. Quote Link to comment Share on other sites More sharing options...
Eric90 Posted July 15 Author Report Share Posted July 15 25 minutes ago, AnthonyB said: Depends - repairs are possible, especially where a notional door would be accepted in the FRA. A competent fire door inspector (one of which is a regular contributor to the forum & should answer at some point) will be able to advise on the viability of repair. Thanks Anthony. Quote Link to comment Share on other sites More sharing options...
