green-foam Posted June 17, 2024 Report Posted June 17, 2024 To disconnect any Aico heat or smoke alarm, you first isolate the mains, remove the detector from its base, then remove the base from the ceiling, then use wago connectors to isolate the cable (One wago block per core) If you have two cables, (One in, one out) be sure to connect like for like colours together so the remaining detectors will still work.) Then restore the mains. But I would have to ask why you want to remove a life safety device? Quote
