Dragos Rusu Posted June 10, 2024 Report Posted June 10, 2024 Hi there, I have a question regarding the gap at the bottom of the door, I have a riser door with a full frame all around, but at the bottom, the so-called threshold is part of the frame, my question is if this gap is treated as a gap around the (2mm - 4mm) or as a bottom gap up to 10mm. Quote
Neil Ashdown MAFDI Posted June 10, 2024 Report Posted June 10, 2024 Noting that the bottom part of the door frame has an intumescent edge seal, I would work on a 2mm to 4mm gap. Have you checked with the door leaf or door-set manufacturer? It would be interesting to see what they require. Quote
Dragos Rusu Posted June 14, 2024 Author Report Posted June 14, 2024 Thank you Neil for getting back to me so quickly. The manufacturer is not on the market anymore, unfortunately, but that`s what I was thinking too, due to the bottom seal. Quote
